97 ZL 440, dies when you turn the choke off
R
Dec 31, 2010
35
4
8
60
Sled ran fine then 2 weeks later took it out and it started fine, took it out of the trailer it ran for a minute then died, started back up and had to throttle it a bunch to keep it running, took it for a warm up ride in the parking lot and it would go, not fast but it would move, as soon as you turn the chock off it dies, you cant even throttle it to keep it running. Any suggestions would be appreciated. Thanks. I did check the filters and replaced.
Posted from Snowestonline.com App for Android
schmeric
New member
Nov 28, 2007
149
4
18
42
I have had ethonal do that exact thing before on older carb sleds. Does it have ethonal in it? If it does drain it out put new gas in and it will run like new
R
Dec 31, 2010
35
4
8
60
Thanks, I'LL pull the carbs and let you know how it went. We are going ridin all weekend. Thank Goodness for back-up sleds.
R
Dec 31, 2010
35
4
8
60
Thanks everyone, took the carbs off this mornin and found some crap in an air port. Took it out and it ran fine all day.
