I Have tested every turbo I can get my hands on. Both on my sled and on the rzr's
The kpa 2863 zinger out performed every turbo on time to spool, Time to torque, and back pressure until we got up to 25 lbs on the rzr's
the 2863z has a 14 gram lighter compressor wheel over the cast 2860. it has the same inducer, same major, and 3 mil extended exducer. the turbo spooled at 174000 r's at 12 lbs the cast only got to 169000. with that much rpm it will produce alot more cfm per pound of boost. this shows that the 2863 has benefits. the 2862 is only $200 more and is worth every penny imo.
the kpa 2863 had faster spool up over the garrett gtx 2863 and out performed until 25 lbs. then the garrett took over until 30lbs. but the back pressure on the garrett was through the roof. the garrett went 1-1 onthr back pressure at 12 lbs. where the kpa never went 1-1 until 20.
garrett was producing more backpressure and heat. this is my independent study.
take it for what it is worth :face-icon-small-ton
