* New Release * Long Rod Torque Master 5 Dragon Motor
Mark's RMK
671
76
Sturgeon Lake, MN
zPiston Side Loading?
What exactly is poston side loading and why does this kit or the one from RKT help resolve it? Indy Dan's kit has longer rods and that seems to make sense that it would help resolve the cylinder skirt issue.
What does the lighter piston in the RKT kit do for piston side loading?
Sorry to ask what might appear to be fairly self evident questions but I like to understand the engineering logic behind these tweaks before I pop for $.
indydan
1,245
3,301
Custer, South Dakota
www.indyspecialty.com
well she didn't make it dan, broke the skirt on the pto piston, which broke off the monoblock skirt which the rod put thru the bottom of the block, dam it
Sorry to hear that HiLine, we can fix it up this summer.
Marks RMk - It does mater what kind of piston you run or how much you change it.........The rod ratio is bad ( The rod is to short )
Its simple math. ( all the piston changes in world will not correct the rod ratio problem. )
Polaris obviously hired a bunch of young engineers that think they know more then they really do.
Dan
indydan
1,245
3,301
Price point Dragon Pro 800
Basic Long Rod Conversion if you send in a running 800 with a good crankshaft & Crankcase.
This Includes Torque Master Top-End with new pistons & Gaskets. & Long Rod Torque Master Bottom-End.
2 year Top-end & Bottom-end Warranty - $2500.00
This Price is assuming all your parts are rebuildable.
Dan
Mark's RMK
671
76
Sturgeon Lake, MN
Loading?
Dan
So, maybe what you are really saying it's front to back loading, the force is in the same plane as the rod? Hence the piston scuffing and loading on the cylinder skirts. And it's not left to right which I would interpret as side loading? Probably answered my own question but I want to make sure I understand what alot of folks must already understand.
If the rods are blue that means they are rotating around the piston too much, generating heat and if you change the length you can cut down enough on the angle of rotation to cut down on the heat generation? And 4 cycle engines with their short pistons must be different because of the oiling differences between 2 and 4 cycle engines?
Thanks in advance for your patience on my questions.
H
160
havre, montana
Dan
i think some of mine won't be:face-icon-small-sho
i'll send in all to you so we can do the same as my 800ves
thanks dan!
H
160
havre, montana
exactly, if you have the top end off and hold the rod and rotate the crank you get a real good idea of how steep the angle is , why they chose to build it that way in the first place is beyond me, seems basic when you look at it
Angermangement890
934
264
Frazee, MN
www.koolmekustoms.com
From what I understand the M8 motor runs more rod ratio then the Poo 800, why do their motors last and not the poo's.
The Cat 800 motors do run a shorter rod than the Polaris. The difference is in the piston/cylinder. The cat piston is taller and the pin is located lower and offset to reduce side loading. The cylinder skirts are also about 2 times thicker than the Polaris cylinder skirt. So if you build beefy parts around the crappy rod ratio, they can be made to last.
R
Dec 14, 2007
14
Dan, you said "Every part used can be bought from a Polaris dealer except the connecting rods & the cylinder spacer." I'm not trying to catch you on anything, but a dealer can sell aftermarket parts. Are the piston's you are using OEM 800cfi pistons?
indydan
1,245
3,301
Dave, I do not run wisecos in any polaris domestic motors. ( Is this what you are asking ? )
Attached is few pictures of Our CFI4 Torque Master Top-End Kit after strength modifications.
The Engine kits we offer for all Polaris 800 small blocks are all about long gevity. For those who have not seen a stock cylinder to understand what has been done here I will post a picture of a stock cylinder also.
Dan
800 PRO TORQUE MASTER CYLINDER 002.jpg 800 PRO TORQUE MASTER CYLINDER 003.jpg 800 PRO TORQUE MASTER CYLINDER 004.jpg 800 PRO TORQUE MASTER CYLINDER 005.jpg 800 PRO TORQUE MASTER CYLINDER 006.jpg
R
Dec 14, 2007
14
Dan, I'm asking what pistons you are using? Thanks, Dave
Dan
indydan
1,245
3,301
I need stock cylinder pictures.
I checked and I don't have any unmodified cylinders right now.
Can someone take a few pictires of a 08,09, or 2010 cylinder bottom at simlar angles to what I took ?
Thank you.
Dan
Dave, at this point I have 3 different Cast pistons I am running in the TM Top-end Kit the verdit is still out on which one I will lock in with. But as I said before and parts can be purchased from a dealer because the OEM pin location & dome shape is the same. I am hoping to be locking in on an after market cast to keep the cost down for replacement pistons with hopes of taking away sales from Polaris.
Does that answer your question Dave ?
Dan
R
Dec 14, 2007
14
"Does that answer your question Dave ? " More or less:face-icon-small-hap
I guess I was wanting to know if it was a Polaris oem cast piston or otherwise. Dave
PaulAnd
2,186
586
Northern IL.
Dan
Does the case need to be clearanced? And how much for cylinder/jug? Nice work!
indydan
1,245
3,301
OPPS!!! Yes you would be correct...... As HiLineRider said if you saw one apart you can see what I mean. ( shorter rods are at steeper angles when the piston is low in the bore )
And when I say side loading I do mean front to back of the motor.
When I say side I mean the front side of the cylinder.
When you talk rod ratios your concern is what is going on from a rotational stand point ( hence ) Front & Back side of the Motor.
Sorry about not making that clear.
Dan
backman
42
8
8
Confused
So if I have a running 2011 800 CFI-2, what will it take as a minimum, to get it safe? Cylinder, rods, and crank work? No modification of case is necessary? Using original pistons?
Regards Fredrik
LoudHandle
3,900
2,775
Valdez, AK
Just curious how you add the bridge between the front and back skirts? It looks like there is a much smoother transition on your updated cylinders, do you press a sleeve in or add weld to the stock cylinder skirts or achieve it by some other means?
