Here’s a suggestion for an emergency blanket that will give you the kind of protection you’ll need if you end up spending the night out. They are usually referred to as “emergency all weather blankets”. They are 4 layer laminate. They are very different from those flimsy little silver “space blankets”.
Here’s a product description from one I found on-line: “Originally developed for NASA, the (product name) All Weather Blanket is warmer than wool. It retains 80% of radiated body heat, preventing hypothermia and providing unsurpassed protection in sub-zero temperatures. Features: Warmer than wool Incredibly durable Multi-ply laminated construction makes it the perfect safety blanket Tear and puncture resistant Can be used for emergency signaling Made of a four-ply laminate of clear polyethylene film, a precise vacuum deposition of pure aluminum, a special reinforcing fabric and a layer of colored polyethylene film Item Specifications: Dimensions: 60"(152 cm) x 84"(214cm) Weight: 12 ounces (340 g)”
They fold up and fit nicely in the bottom of your backpack. Most have grommets. Some have hoods.
Every one of our packs has one. I also carry them hunting or hiking. Our old jeep has a couple in the supply kit.
Do a search for “emergency all weather blanket” and pick the one you like.
