2017 RMK Pro 800, 155" 2.6 (with QD) Silber Turbo (non-intercooled).
Sled is brand new, 0 miles, only started to unload from truck. Installed a Silber turbo kit. Tank already has the added VES Gold. I made sure the turbo was primed w/ oil etc.
Is Polaris still recommending 100 trail miles to break in the QD belt? My old snocross sleds, we'd break them in the right way, on the dyno.
My plan: run the 3psi spring, do some road riding ~30-50 miles, varying throttle input...Stop every so often to let the engine cool, to get some good heat cycles and let the rings seat properly..and get some good heat cycles in the QD belt..also, check all hose clamps etc.
Most of my riding is between 5'-8'k, plan on running the 5psi spring for the majority of the winter. Planning to run ~30% av fuel (100oct) w/ 92oct from a top-tier gas station, aka: Shell.
