I have put vf3 reeds in a 800 assult. The idle has dropped off or gotten lower over a short bit of running. I'm thinking maybe a pedal broke or just is not sealing well, if a reed has problems does the spark plug color for that cylinder usually go darker or lighter? New spark plugs from the time of the reed instalation look different.
I am thinking of basic tests to sort it out, perhaps a heat gun reading on each side of the y pipe could indicate a starting point?
I tryed new spark plugs - no improvement
I will get a compression tester on it this weekend but it was equal at 120lbs right after the build with new cylinder and Pistons.
On the first short ride the temps stayed within a few degrees of the other polaris800 following along doing same things.
I notice the idle is low but other than that it's not heating up or bogging so I thought I would ask for ideas to try before I dig in and check the TPS
I wish I had a leek down tester at this point it may help point out out a problem
