2008 nytro wiring
O.B.
297
54
missoula mt
Trying to help a buddy out. When the ignition switch is in the on position. There should be power on two of the wires at the switch. One in and one out . Is that right any help would be great. Thanx
2Huskies
581
206
Is your kill switch up? haha
On a more serious note if you are running a tether those can go bad as well. But yes if the kill is up and you turn the key the first click you should get display.
I just replaced my start relay bc it wasnt working, but i still got display. But it still could be that.
roughrider99
1,805
252
83
33
Fernie,BC
Have power at the ignition leads? Jump the key switch, if no go Test voltage throughout the circuit from the battery up. If that's good check relays
