Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 03-05-2012, 08:44 AM
MissionMtnMax MissionMtnMax is offline
Currently: Not set.
Basic Member
MissionMtnMax has a reputation beyond reputeMissionMtnMax has a reputation beyond reputeMissionMtnMax has a reputation beyond reputeMissionMtnMax has a reputation beyond reputeMissionMtnMax has a reputation beyond reputeMissionMtnMax has a reputation beyond reputeMissionMtnMax has a reputation beyond reputeMissionMtnMax has a reputation beyond reputeMissionMtnMax has a reputation beyond reputeMissionMtnMax has a reputation beyond reputeMissionMtnMax has a reputation beyond repute
Default '98 MXZ 670 died on me in the middle of nowhere.
I took my wife's sled out for a run yesterday - plenty of snow, but very warm day. I stayed on roads that had sled tracks as I know soft snow can be hard on belts. We've only had this sled for a little over a month - needed a new top end right away, which we had done by local shop. Have put on about 140 miles since then. So I'm out running around in the mountains and first, I start smelling rubber burning about 10 miles into my ride. I got to a good turn around point and thinking the belt was giving out, so started easing back towards my starting point about 20 mph. I hadn't gone a quarter mile and I hear a "fwap fwap fwap" from under the hood - so figure belt is giving out. So I continue driving slowly to get back on the main roads where trail was not as soft as this road I was on. But about 30 seconds later, the engine started bogging down - like not getting gas or something and sure enough within about 15 seconds, it died right there. Being rather new to this whole scenario my first thought was "would the belt giving out cause this to happen?". I couldn't see that happening. Belt was slightly fried on the one side but I felt it could've still made it back. So I tried re-starting and nothing. Changed over to new spark plugs and still nothing - won't even fire. So I had no choice but to start hoofing it. Did finally run into some sledders and got towed out. One of the guys back down at parking area said he had one of these machines and was pretty sure it was CDI based on his experience. Normally, the sled starts up by the third pull cold, and within two when warm.
So do I try a new/used CDI? Anything else I could be looking at? Wiring looks intact and sled has only been driven on ungroomed or groomed trails.
Rate this post: Yes | No
  #2
Old 03-10-2012, 02:11 PM
bullelkklr bullelkklr is offline
Currently: Not set.
Basic Member
bullelkklr is an unknown quantity at this point
Default spark, compression, fuel
Make sure you have them all before you go buying parts. Rubber smell and CDI failure would not seem to go hand in hand.
Run a compression test.
Test to see if you have spark
Make sure that you are getting fuel.
Buy a manual on-line (for like 5 to 10$) and it will have the troubleshooting information in it.
you will go broke if you start just buying parts and pieces without doing any troubleshooting first.
  #3
Old 03-10-2012, 02:13 PM
Currently: Not set.
Basic Member
Default ? soft sno?
What is it about soft sno that is hard on belts? your thumb is the only thing that is hard on belts, if the primary and secondary are properly aligned it should not matter.
We have about 5 feet of soft snow here - my belts are fine......
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 98 mxz 670 Thread Starter — 800mtefi Forum — Ski-Doo: S-2000 and older Replies — 2 Last Post — 01-23-2010 01:09 AM
Thread — 98 mxz 670 Thread Starter — 800mtefi Forum — Performance/Modified Replies — 2 Last Post — 01-22-2010 09:26 PM
Thread — 98 mxz 670 Thread Starter — 800mtefi Forum — Racing Replies — 0 Last Post — 01-22-2010 05:05 PM
Thread — 98' ski doo mxz 670 h.o. Thread Starter — malbert26 Forum — Ski-Doo Replies — 1 Last Post — 01-15-2009 01:58 PM
no new posts
