T
For Sale due to Health issues my Uncle must sell his new 40th annv 2008 Nytro RTX Short Track with Fox Floats. The sled has 70 miles on it and it a rocket ship it sails!! Here is your chance to save $$$ on this as he needs to get rid of it! The price is $9399.00 OBO and list price was $10799.00. The sled is located in Lewiston Id. Give a Pm if interested also sled warranty is transfered to buyer. Happy Sledding..
MSRP* $10,399
$10,699 w/Reverse
$10,799 40th Anniversary
Engine
Type / Displacement / cc Four-stroke, 1049cc
Cylinders Three
Horsepower Class 130 HP
Cooling Liquid
Bore & Stroke / mm 82.0 X 66.2
Intake Design 2 Valves
Ignition Digital T.C.I. w/Throttle Position Sensor
Carburetion 41mm Mikuni®, Fuel Injection
Exhaust Rear Exhaust
Clutch / Transmission YVXC, Variable Ratio
Disc. Brake Type 4 Piston Hydraulic with Lightweight Disc
Chassis
Front Suspension Independent, Double Wishbone
Front Shocks Fox™ FLOAT™ Air Shock, Aluminum
Front Travel / in. N/A
Ski Type Lightweight Plastic, Saddleless Design
Carbide Ski Runners Standard
Stabilizer Bar Standard, Linear Ratio
Rear Suspension Dual Shock™ Pro
Rear Shocks 40mm HPG w/reservoir, dual-clicker / 40mm HPG w/reservoir, dual-clicker adjustable
Rear Travel / in. 14.5"
Dimensions
Overall Length / in. 108.5"
Overall Width / in. 48"
Overall Height / in. 42.9"
Track/Width x Length x Height / in. 15" X 121" X 1.25" Camoplast Rip Saw™
Estimated Dry Weight 513 lbs. / 520 lbs. (reverse model)
Ski Stance (ctr. to ctr.) in. 41.3"
Fuel Capacity / Gal. 7.4
Fuel Type Regular Unleaded
Oil Capacity / Qts. 3, Dry Sump
Engine Oil Type Yamalube 4, 0w-30, Cold Weather Formula
Features
Electric Start Standard
Reverse Optional, model with reverse also available
Hand & Thumb Warmers To-the-end, 10-position adjustable
Windshield Height Low
Mirrors Optional
Seating Capacity One
Backrest N/A
Rear Carrier Rack N/A
Tow Hitch N/A
Tunnel Protectors Standard
Headlight Watts, Type 60/55W Halogen x 2
High Beam Indicator Standard
Oil & Temp Light Standard
Fuel Gauge Type Electric (LCD), Low Fuel Warning Light
Speedometer Standard (LCD, Digital)
Odometer Standard (Large LCD Display)
Tripmeter Standard, Backlit (LCD)
Tachometer Standard, Backlit (LCD)
DC Outlet N/A
Color Team Yamaha Blue/White; 40th Anniversary White/Red
Warranty 1 Year (Limited Factory Warranty)
MSRP* $10,399
$10,699 w/Reverse
Engine
Cylinders Three
Cooling Liquid
Chassis
Dimensions
Features
Mirrors Optional
Backrest N/A
Tow Hitch N/A
DC Outlet N/A
