We just finished with building a new house and the basement was left unfinished. We wanted to get the exterior walls insulated before the long cold days of winter set in. We have poured concrete basement walls and the 2x4 framing is already up.
My question is, which form of insulation is considered the "best" these days, is it the traditional fiberglass batt insulation or the foam core panels?? Anyone have any experience with both?
From the little research I've done it sounds like people are starting to like the panels more and more. Easier to install, don't have to worry about moisture, provides a better seal, and is cheaper.
Are there different R-values for the foam panels?
Also, is it easier to have the wiring done b/4 we put in the insulation? I assume so, especially if you use the batting. We have some of it ran but not all of it.
Thanks in advance...
