Any of the small block Polaris motors (440, 500, 600) were/are bulletproof. I can't remember if this motor is with or without variable exhaust, but either way it was a stout motor for a 500. With the electric start it gains a bit of weight, but it will be forgiving on a weaker arm. At a 1000 bucks you could add a few things that this is going to need. Namely a set of Better Boards, a handlebar riser and mountain strap, and maybe a deeper lug track for when she goes off trail. 1.25" really stinks (that's what I started with). That and the skis from that sled dart a lot on trail. If you could afford it, I would look for a 2002 or newer 600 RMK in the EDGE chassis as the motor is significantly more powerful (smooth power though), and the chassis is more user friendly than the Gen II. But, if this is your price range, it seems like a good deal...good luck with the first outings!
