hi guys, discovered very little crack, on the upper left corner of where your reeds would go in, the cylinders have been ported, so im thinking maybe its a casting imperfection??? afterall they where ported...., thanks!
Note: this_feature_currently_may_not_be_available_in_some_browsers
it is strange that the crack is opened up that far,I would really have it inspected thoroughly by cylinder shop. then weld as needed if everything looks good, was it running well when pulled down?A crack that visible could easily continue elsewhere not you may not be able to see it
I'd get it fixed while you have it apart
Who ported it
Jason, Ive seen a few of them brake the reed box off when running after some grinder got into the bolt holes.
you like to gamble ? go to vegas!!!
run cylinders that are not cut
