I have a 10 m8 sp and I want a little better backshifting does that shift assist from D&D really work? I have ordered rock rollers for it also. Any other suggestions?
Thx
Thx
Thx
depending on the primary weights a split angle (radius cut i think) helps quite a bit on the upshift of the compression style. You should change out your springs every 500-1000 miles in my opinion. everyone I've tested after 500 has had a lot less tension than stock.
shift assist and rollers are a good upgrade, most likely you will loose 100-200 rpm and may need to shave some weight from the primary clutch weights. when you put in the shift assist remove one plastic washer and leave on in.
What about with the titanium spring?
