Inlet barb fell out of my oil pump
88
19
Calgary AB
Anyone know if I can press it back in or just order a new pump? 2012 800 RMK
This is the main oil feed line, the brass connector (90) fell out and is still in the hose hanging below. Oh yeah my garage is a skating rink...
skibreeze
10,463
3,477
Colorado Springs
This exact thing happened to my 12. Got a new motor under warranty. I would be very concerned that it ran with no oil. I would also not be convinced that the fitting wouldn't fall out again.
Post up a pic of the fitting, I'd like to see how much knurling is on the fitting.
Reg2view
2,392
1,600
Jeez, that's an issue. No way I'd trust that pump again - if you had a warranty, I'm sure you won't be asking. Bummer, is this a pump QA issue, anyone outside of 12's? Lotsa floor dry needed.
88
19
Calgary AB
Also the best tip ever, drill out 10 rivets and peel back the bottom pan to access. You can see how easy this will be now. I was worried about the time it takes to pull the engine....
1441190_10152057083556718_2118065592_n.jpg 1450294_10152057083456718_243382351_n.jpg
Dec 15, 2013
Same thing happened to my 2011 assault yesterday glad I didn't burn her up how did you get it to hold back in? Some gasket maker or sompething?
O
obile
Jan 17, 2003
349
27
walla walla wa
clean the njpple and the hole it goes into ream it out a little so its a loose fit. locktite 680 sleeve retainer coat sparingly inside hole and outside of nipple.twist to clock the nipple Done it will never come out.
