R
Hey guys. I have a 2011 pro rmk 800. I'm having a bogging issue I'll explain as best I can. I start the sled and let it get to temp before riding. When I go play around and give it some throttle lets say wide open. The sled will rev to 6000 and do about 30-35 mph and that's all. Then if I burp the throttle. (On off on off on off) it will l of a sudden gain full power and pull very hard. The second I let off the throttle a little bit it starts bogging again. Then again I have to play with the throttle on off on off to get it to run right. Also if I hold it at one spot on the throttle you can hear the sled sounding funny like a miss or going back n fourth from one to two cylinders. Did compression test got 112 on both with throttle closed
