So after a lot of testing and troubleshooting, I have found the solution to the throttle bog in higher elevations (on/off throttle jabs boon docking and heavy load throttle re entry).
First and foremost. Make sure your power valves are clean!! This is a must. Also check the lines going to the solenoid. Make sure the plastic fitting is snug and not leaking on the inlet side.
[/URL][/IMG]
Second. I currently run the external waste gate, reflashed ecm setup with a 10 psi spring. I run around 9500-11,500 ft.
I have found that a pink primary spring (team 180-320), 10-72 weights, 44 straight helix works outstanding. I have found running a reverse split helix seems to build to much belt heat and shifts to much. This clutching setup WILL ELIMINATE the on/off throttle bog @ 10+psi, 9500-11,500 ft.
For those of you running lower boost and elevation, I would recommend starting with 10-74's.
The sled is extremely sesitive to clutch weight.
People need to keep in mind that a turbo charged two stroke motor is a difficult engine to keep happy 100% of the time and will occasionally "fart, blurp and stutter". I have a 2015 all out built VOHK pro, 2x aerocharger kits, 3x boondocker kits and one Silber setup. THEY ALL HAVE THERE QUIRKS.
This Silber sled is by far the best running kit I have. If anyone has issues's PM me and I can most likely help. I also have a shop in Casper, Wy and make lots of trips to Togwotee/Snowy Range.
