MY 2014 SILBER TURBO 800 SEEMS TO RUN HIGH EGT TEMPS, AT 5000 FT. I CAN SEE 1290-1450 IN THE MID RANGE, SWITCHING IT TO ETHONAL MODE HELPS, BUT 1300-1400 IS EASY TO DO. MY PROBES ARE AT APPROX 6 INCHS FROM THE PISTON SKIRT. PLUGS LOOK SUPER WHITE, AND IM RUNNING STRAIGHT AV FUEL, WITH A TOUCH OF OIL. SILBER REFLASHED MY ECU LAST JANUARY. 7 PSI SPRING IN THE WASTEGATE. MAG SIDE RUNS THE HOTEST.
UNDER WIDE OPEN TEMPS ARE 1150-1230 ISH.
DOES AV FUEL NOT TAN UP THE ELECTRODES ?
ANY THOUGHTS OR INPUT WOULD BE VERY HELPFULL.
