I looked at another chart for a 1998 RMK700 and it calls for 158 main jets for 6 to 9000 feet at temps of 10F to 40F. It was non ACCS for that year so it may be close to what you should jet to. It used 1371G needles with the clip in position #3 so you are good there. The only difference is that your carbs have a 6.0 throttle valve and the 98 had a 5.5 valve. That means your carbs run a little bit leaner on the bottom up to about half throttle but Keihins run pretty rich anyway. Taking that into account I would think that 160 mains would be right for a starting point for your sled for 10F to 40F. Of course the best would be if someone that removed the ACCS from a 2000 RMK700 would chime in with their setup.
Overly rich jetting will definitely give a low end bog.
