H
- bought a spare engine mount setup from product tester
- had to fab up a metal support as the alum support is backwards and upside down
- used a 3/4" long bolt on the bottom, cap screw wont work, hex head requires less room....and you need all you can find:face-icon-small-dis
- shimed 2 washers inbetween the mount the rubber ring thing
- removed material from the rubber ring thing as i need more clearance for the oil pump...started with 1/32" and ended up with about a 1/4"...fingers crossed
- removed material from the half moon bracket located down low and cut a hole in the bulk head to gain bolt install/uninstall access.....plan to cover this hole up later
- used loctite on everything
- you will need a long pry bar to move the engine around and get the lower bolt in....this is the fun part
- PITA:face-icon-small-dis
engine side mount, looks purdy huh:beer;
topside view:
see the hole, the bolt is long, could of done it differently i guess.....oh well
oil pump vibration/movement room:
bottom half moon clamp, removed material amd removed about 1/8" from the bolt as it will now be too long:
topside view:
