2005 900 151" & 166" Combining
Feb 3, 2017
Looking at combining my 151" and 166" to make 1 badass 900. The 151" has a lot of the goodies, but the 166" has the 166" and a few electronic goodies that I would like. so, the big questions:
1- can I run the 166" with the 151" tunnel?
2- Will the Mt. Tamer suspension on the 151" work on the 166" skid?
The reason for the 151" tunnel is that a lot of the upgrades have already been done,
and the 166" is pretty much stock. Both sleds have about 60 hrs. on them.
The 151" Has: Radiator delete, Intake and clutch cover, torque arms and bump stops, 2008 spindles, slp pipe and can, slp Powder pro Skis, Bars risers and hand guards.
I still need to do the engine mount upgrade, rider select delete, and send the clutch out for balance.
The only issue that im having on both sleds, is after last ride, 1 tank of fuel, oil tank is all but empty, so I will be checking the cable and return spring this weekend. Thank You Brothers.
SixtySevenGT
803
116
Middleton, Idaho
2005 / 900 Chain Case
I have a longer chain that would fit you 2005 chain case so you can run the 19/42 gears if interested.
I also have a set of Avid anti ratchets (2.52) mounted on a 2005 Drive Shaft.
FYI - 2005 Drive Shaft and chain case are unque to only that year.
