After 1059 miles I had two bad bearings. Both had were spinning on the shafts and caused some damage. Neither chain case bearing had sized at the time of replacment.
My sugestion is if you have a new MH kit all should be good for at least 500 miles, if you have last seasons kit 300 is the upper limit.
I know that Timber Sled is looking for the perfect bearing and they are much improved this year.
For next seasons kit TS has machined the bearing retainer and opened the ports in the side panels, to shed water for even longer bearing life.
Upon replacing my bearings I did some roto tooling to help shed some water. This is a rough copy of what TS is doing for next seasons kit. See pic.
These MH kits are the S### and some maintance is required. So do your self a favor and spend some time changing/checking your bearings.
I got 4 bearings (best bearings to date) from TimberSled and changed all drive bearings so I can ride another 500 miles with out any issues.
Thanks to TS for the great product and for the ongoing improvments.:usa2:
