P
Sled seems to run perfectly fine but my headlights flicker from really dim to normal intermittently while riding. In addition, my dash flickers on and off when I stop and let it idle and sometimes will stay off, Tap the throttle and dash stays on no problem.
Anyone have any ideas of what could be wrong? Stator or voltage regular? What should these test out at with a meter?
I tested the voltage reg while running and had no voltage on the orange wire plug.
Brown and red wire plug
7VDC at idle, 13-14 at clutch engagement
Yellow wire plug
8VAC at idle, 12 at clutch engagement
Yellow wire plug
