rmk 700 2002 not giving full rpm on full throttle
Troll-Tor
New member
37
4
8
Strange:
On full throttle the sled revs to 6300 rpm and stops there.
If i keep myindex finger between handlebar and throttle it revs to over 8000 rpm.
Temp sensor changed to brand spanking new and TPS adjusted to 4.00
Anyone with same experience who found out the reason?
I was told the sled started doing this after a big roll downhill
sled_guy
3,566
843
Riverton, Utah
Check and make sure the exhaust outlet is not pinched shut. Also, might pull the muffler off and shake it to make sure the baffle inside hasn't come lose and fallen down and closed off the outlet.
Check your exhaust valves... if they or even one isn't opening then it won't rev over 6500-7000 rpm.
sled_guy
