what is this rear kit you speak of? cannot find it on their website
thanks
we do have braces for the rear and center of the tunnel also
Note: this_feature_currently_may_not_be_available_in_some_browsers
thanks
thanks
VE kit is compatible with the assaults.
For yours... i would get the full version that requires the chaincase to be pulled... remove the track/shaft/chaincase...Straighten everything out as best as possible and install that kit.
ours is for preventative, so if you did not get the fastrax pro-tectors in time, then you will have to do the more labor intensive bigger plates from other companies
Just installed a set from Fastrax and a set from FNI-on 2 different sleds-
For the ease of install- yes fastrax is easier and suggested on non kinked tunnels- the Fire and Ice was more labor intensive and provides a broader coverage of the tunnel area.
Is all that needed? - It is a consumer decision- and a peice of mind-
The FNI was put on a a sled where drops come often for this rider- as to why we went this route-
All in all- Both work /
Cheap insurance for what seems it will happen not "If but When"
S/C
when you bend the tunnel it is a lot of work, I just repaired one and I had the sled stripped completely down to tunnel and bulkhead to repair
Just got finished with the install of the FTX braces. I am really telling you it is about as easy as changing a spark plug. Took about 30 minutes total from start to clean up and ready to ride. Directions were great. Product was great. Thanks Fastrax.
My install wasn't so easy...
I just finished my install, and it was easy until I got midway thru the chain case side......damn battery box is in the way for access to the chaincase carriage bolts. I didn't want to remove it.....so after some thinking..I was able to remove the 2 lower Torx support screws, and 2 10mm nuts on the battery box rear bracket to move the box approximately 1" forward. Also, had to remove the chaincase filler screw for socket clearance.
All in it took about an hour, including some troubleshooting time...lol!
Kit fit well, and everything lined up.
Hope this helps others who are installing the kit on sleds with electric start.
