P
My buddys 01' 700MM is over reving. Motor stock except single layer headgasket and Bender can. It also has reverse and been stretched to 151. This thing revs over 9000 consistantly. We have pulled The primary cleaned and replaced the spring and added 4.5 to the outter hole.(already had 4.5 in the inner hole). Pulled secondary, cleaned and replaced spring and buttons. I'm sorry I can't remember whar gears are in it right now and we did try gearing it up one tooth. But he did add the reverse himself and I am wondering on the gearing. Two questions, What gears should he be running? Can over reving be caused by an out of aligned motor? Thanks
