Anyone know why my sled might be idling high, around 2500RPM? Changed the fuel filter and had the TPS adjusted by local shop this season. Sled runs perfect and doesnt skip a beat it simply just idles high. Anyone have an suggestions?
Does it EVER go down?
If you blip the kill switch, does it settle down?
Turns out its the crank seal it idles down for a couple seconds when you spray behind the clutch. How hard is it to change can I leave the motor in the sled pop the clutch off and do it right there or is it a bigger job?
Im assuming the risk I run by running the sled is leaning out and melting my motor, or seizing the crank?
It can be a bit time consuming, expect one evening to tear it down and one to rebuild it.
I wouldn't tear it all down and not replace both crank seals, water pump gasket, injector orings and piston rings while you have it all a part.
