If your sled has been sitting since last season, with the old gas in it.
If you have not fired up your sled yet for the season...Best to drain ALL the old gas out... ALL of it.. and fill with fresh... with your fuel system cleaner of choice and some pre-mix oil... and, without starting the sled.... run the fuel pump on prime mode for about 5 minutes to flush the, pickup, pump, fuel lines, fuel rail of any varnish or sludge buildup.
The moment you fire the sled... what ever is in the lines... be it fresh gas or old gas... will be pushed through the injectors.
Priming the system leaves the injectors closed... but circulates fuel through the entire fuel system.... best to start off the season as fresh as possible. If you run the prime for a while... the first fuel the injectors will see will be as clean as possible. :face-icon-small-hap
