great project, loved seing it transform
you mad some mad skillz my friend
i really want to get a foot well vent, but my 2012 600 144 RMK is a bit different then the 800's
as you can see it has a few bends in it
any chance you can get your hands on one to make one??
Thanks, I appreciate the compliments.
You know, I don't have any 2012 RMK 144's in our group this year but I do have a dealership close by.
I don't think it would be all that hard to make a vent for that, just time consuming. I would guess that I have about 20-25 hours into my vents. Part of that time was figuring out what I really wanted. I wanted something different than everyone and something subtle but still functional.
Process I used
1. You need to get some poster board and make a template of the footwell - noting the ovals, aluminum or air space, and Z bends.
2. Then you would need to make another template (side profile) of the actual Z bend. This will be your guide for bending the ABS.
3. Trace #1 template to ABS - cut out.
4. Heat up ABS and bend per #2 template.
5. Cut out air flow holes.
6. Clean up edges with Dremel and/or belt sander.
7. Decide if you need to make it a two piece or one piece template.
8. Clean back side of ABS with Rubbing Alcohol a few times.
9. Lay a bead of adhesive on the backside of ABS and lay down the mesh.
10. Let cure over night - depends on the adhesive.
11. Add prefilter material - if wanted.
12. Cut excess mesh/pre-filter material off.
13. Install.
Of course I didn't add how many times you need to test fit. Good templates will limit this process but you should always test fit before drilling for rivets.
I won't have time to look at the local dealer this weekend due to a leaky crankshaft oil seal on my car that needs replacement. If I get time, I will swing by there and see how well my current template works.
