06 340 edge touring stator specs
G
Mar 10, 2017
7
Anyone have a link to a shop manual for 2006 340 edge touring? Don't mind paying but free is always better
I can find for 06 340 classic and 06 340 Indy touring but not the 06 340 edge touring
Even if someone has stator specs would be good
whoisthatguy
811
248
If you have stator problems, either the engine doesn't work or there no power for the accessories. A bad high low beam switch can screw up the engine so that you may think that you have a stator problem. You disconnect that switch and see if the engine runs, it order to check for whether it is bad. If you need serial numbers to by a used stator, go to Carl's Cycle website. A bad thermister on top of the engine will also cause the engine not to work. You can check whether that is bad by disconnecting the connector and inserting a wire that connects the two ends of the electrical harness connector that you just exposed. If the engine then runs, you need to buy a new thermister for about $22.
G
Mar 10, 2017
7
What is a thermister? I have never heard of that term or know where to even look for it
retiredpop
1,350
295
Calgary
Stator specs should be the same as for the 2004 340 touring shown in attachment. The manufacturers don't tend to make electrical changes within the same chassis/ engine combinations year to year. The wiring diagram should be okay to follow too.
G
Mar 10, 2017
7
Thank you very much
whoisthatguy
811
248
I am referring to the screw in plug on top of the cylinder head cap, with a lead wire that plugs into the main electrical harness, right in front of the coolant hose connection. When the engine over heats or the thermister gets old, then it breaks the electrical connection that either causes the engine to stutter or to not work at all.
G
Mar 10, 2017
7
My engine is a air cooled
