Upgrade to Premium
Reply
  #1
Old 11-15-2018, 03:11 AM
Murdock253 Murdock253 is offline
Currently: Not set.
Basic Member
Murdock253 is a splendid one to beholdMurdock253 is a splendid one to beholdMurdock253 is a splendid one to beholdMurdock253 is a splendid one to beholdMurdock253 is a splendid one to beholdMurdock253 is a splendid one to beholdMurdock253 is a splendid one to beholdMurdock253 is a splendid one to beholdMurdock253 is a splendid one to beholdMurdock253 is a splendid one to beholdMurdock253 is a splendid one to behold
Default 2013 kx450 questions
I just have a question regarding air forks I have 2013 kx450f I really want to build a snowbike thinking about buying a fx450 on a pretty good deal but Iím willing to go bare bones I just want to to know how I get around the air fork issue they will never work for snowbiking
Rate this post: Yes | No
  #2
Old 11-15-2018, 03:24 AM
Currently: Not set.
Basic Member
Default UPDATE 2013KX450 SNOWBIKE QUESTIONS
Could use any 48mm fork set? I found a set of oil forks off an 2004 KX250F for super cheap I have the means to get them resprung and adjusted would this be a viable option?
  #3
Old 11-15-2018, 04:43 AM
Zad Zad is offline
Currently: Not set.
Basic Member
Zad is an unknown quantity at this point
Default
While I have no personal experience I have a friend who uses kx air forks. He puts on fork socks and greases the fork dust seals and they work fine, no loss of air.
  #4
Old 11-15-2018, 09:35 AM
M5- M5- is online now
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
Quote:
The 48mm number as you know is the tube dimension. What you need to know is the triple clamp dimensions. If you buy a set of forks it might be best to find a set with the triples included. From there go to the All Balls site and use their fork converter to find a conversion bearing. This still doesn't guarantee the stems will be the correct length. So bottom line is you will need to do some homework and measuring if you want to be certain. If the clamp dimensions are the same that's by far the easiest swap. Straight bolt on.
M5
  #5
Old 11-15-2018, 03:47 PM
Currently: Not set.
Basic Member
Default
So what year of Kawi does your friend have? Just curious I have the first generation of air forks so single chamber does anyone know about oil conversions or if the air pro works on air forks I donít onow anything about the air pro setup
  #6
Old 11-17-2018, 10:09 PM
Zad Zad is offline
Currently: Not set.
Basic Member
Default
He’s got a 2013 I think, either that or a ‘14. I also bought a ‘14 this summer to snowbike (have not used it yet) and I bought it after reading a number of threads where people used air forks with socks and had no troubles with air loss. From what I understand if you have a warm garage where your bike can dry out overnight and you grease the fork seals and use socks it’s rare to lose air on them.
  #7
Old 11-19-2018, 02:12 AM
Currently: Not set.
Basic Member
Default
Zad I think Iím buying a raw 120 kit this week for the Kawi just gonna go cheap and see how she holds up 🤘🏼 I would love to know if you have any setup tips or help tips for the kx450 snowbike please let me know message me on here Iíll be pretty active Iím very novice in snowbike setup maintenance etc. been reading a bunch of these forums any help is appreciated thanks 👍🏻
  #8
Old 11-19-2018, 03:04 PM
Zad Zad is offline
Currently: Not set.
Basic Member
Default
Sent you a PM.
  #9
Old 11-20-2018, 01:05 AM
jeiner jeiner is offline
Currently: Not set.
Basic Member
jeiner has a reputation beyond reputejeiner has a reputation beyond reputejeiner has a reputation beyond reputejeiner has a reputation beyond reputejeiner has a reputation beyond reputejeiner has a reputation beyond reputejeiner has a reputation beyond reputejeiner has a reputation beyond reputejeiner has a reputation beyond reputejeiner has a reputation beyond reputejeiner has a reputation beyond repute
Default
Don't buy a raw. For the same price you can pick up a 2016 or 2017 ST.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Set up questions 2015 KX450 with Camso Thread Starter — Watson777 Forum — Snow bikes Replies — 2 Last Post — 02-07-2017 05:10 PM
Thread — what air fork psi for 2013 kx450 Thread Starter — jrddillon Forum — Snow bikes Replies — 0 Last Post — 12-18-2016 05:16 PM
Thread — 2013 kx450 thermostat (which one) Thread Starter — dirtbiker250 Forum — Snow bikes Replies — 3 Last Post — 04-10-2014 06:41 AM
Thread — 2012 KX450 W 2013 Timbersled ST Thread Starter — moresnow4 Forum — Snowbikes & Parts (Swapmeet) Replies — 0 Last Post — 01-22-2014 09:42 PM
Thread — 2009 KX450 w/ 2013 Timbersled Mountain Horse ST Thread Starter — hainesrx Forum — Snowbikes & Parts (Swapmeet) Replies — 2 Last Post — 01-21-2014 08:45 PM
no new posts
