Upgrade to Premium
Reply
  #1
Old 10-27-2018, 07:14 PM
Ben 500RR-S Ben 500RR-S is offline
Currently: 18 Camso DTS 129
Basic Member
Ben 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond repute
Default KTM 300 XC-W 2008, Misha Subo, please help me, I will be installing . . .
. . . the third Camso DTS 129 kit on the 2008 KTM 300 XC-W. My BIL's bike.
I will be buying a Ski Doo Expedition from him so my wife can ride it and we can all go riding and my brother in law will get a Camso DTS 129 kit for the bike and I will install it on the KTM.
Is there anything I need to know or that I need to get for the 300 XC-W to make it all run good?
Engine jacket.
Thermobob?
Heated carburetor?
My appreciation in advance.
Rate this post: Yes | No
  #2
Old 10-28-2018, 08:27 AM
Misha Subo Misha Subo is online now
Currently: 2 x('18Camso/'08KTM300 XCW)
Basic Member
Misha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond repute
Default
I have not installed any of those often talked about items on either of our 2 xcws. No carb heat, no filter jacket or skins...nothing so far. Yes, these things were all on my list of things to do last winter but just got too busy. I started to plumb up my own glycol heated handle bar system and air-charged forks but did not finish when spring came around and both of those mods would not make an engine difference anyway. They are on my 2019 list once the garage is insulated and heated this fall. Also, put a thermometer style radiator cap on both bikes to monitor rad temps which was helpful in comparing both bikes which are identical in all ways except using the Suzuki needle/jet in one of them.
Did I have running problems last season up here in sub/sub zero great white north? ...no, not really. Just the first ride during x-mas in -20 deg temps was a little troublesome getting the bikes started and one of the xcws has a much higher operating temperature once warmed up which could be due to a small leak in the rad-half. I think this year we will play by ear and do the minimum trickery only if needed but definitely finish off the handle bar heat and charged forks. A stiffer front suspension will help with control but really very happy with the 2T bikes on the snow and Camso's kit so far (4-5 rides last winter).
The Following User Says Thank You to Misha Subo For This Useful Post:
Ben 500RR-S (11-21-2018)
  #3
Old 10-28-2018, 09:09 AM
CATSLEDMAN1 CATSLEDMAN1 is offline
Currently: one ski and a KTM
CATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond repute
Default 300 ktm
in the backwoods of Montana you won''t ride many days without carb heat. Hit the wrong conditions and a half mile at a time limping back to the truck maybe.
along with that cover the motor to help, for sure a 2 stroke thermo bob, some get by with stock KTM ( which years ?). I like a wrapped pipe becuase in lots of fluff otherwise clouds of steam slow going up in your face fogging the best goggles.
after that the list is endless. firmer forks......good
better foot pegs or cover stock with bike inner tube
temp gauge
I have no first hand experience with the Comso ski to make it handle ?
  #4
Old 10-28-2018, 09:34 AM
M5- M5- is online now
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
My main complaint with the Camso ski is the" no mans land feeling" going from the center runner to an outside runner when cornering hard on the trail. Basically you have to lean the bike over and hope and pray the outer ski skeg hooks up. They did exactly what I thought it needed for 2019. There is a new deeper outer keel with a vertical component like the Yeti ski. They have also added 4 ribs to the corners of the ski in order to add more torsional rigidity. Both of these changes I think are directed towards improved trail manners. In the deep I found the ski is pretty decent because of the large shovel and its huge width.
As for your 300, I wouldn't run without carb heat, I've had a 2T with no carb heat freeze wide open and its no fun. Sorry MS but 4-5 days is not a test. The thermobob, maybe take it or leave it, I don't have one I just block off rads as needed. I would spend the money for a real temp gauge though and mount the sensor at the head. Those rad cap things are crap they are inaccurate for true head temps and they are slow. Watch a digital temp gauge and you will see how fast your temps change.
M5
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to M5- For This Useful Post:
Sheetmetalfab (10-28-2018)
  #5
Old 10-28-2018, 11:50 AM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Getting the R6 snowbike ready......
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
Quote:
M5
Yep.
__________________
Try again
  #6
Old 10-28-2018, 12:06 PM
Basic Member
Default
I did a little ice racing 30+ years ago and had carb icing issues, in what seemed to be far warmer temperatures than last winter's snow bike outings. I think icing tends to be influenced by humidity as well. Up here in Southern Ontario it is dry by the lake in the winter but more humid than most regions during the summer...but I do plan to address the carb heating issue this fall just for fun and before I have to snow shoe home.
I bought a new lathe so I will attempt an intake heater circuit similar to the one I was posting here last winter. I want to keep the stock lower hoses and t-stat for summer use and remake a new carb/handlebar heat circuit just for winter - anyone have any ideas on this? I have already bought the fittings and lines for carb and handle bar heat but got side tracked by ski trips last winter. The plan is to do a combo ski/snow bike trip out in Quebec this February so I want to be reliable enough. Before you know it the winters over!
  #7
Old 10-28-2018, 12:23 PM
Default
Humidity comes from snow melting off the pipe and engine. (Steam)
Also a 2 stroke carb venturi is especially susceptible to causing moisture to freeze and stick the slide.
I’m guessing you never rode in deep enough snow to have icing issues.
My 2 stroke had icing issues at 34 degrees. (From the cooling effect of fuel air venturi)
__________________
Try again
  #8
Old 10-28-2018, 01:47 PM
Robbie's Avatar
Robbie Robbie is online now
Currently: Not set.
Paid Premium Member
Robbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond repute
Default
Carb ice is a temperature/ dew point issue.
https://www.atsb.gov.au/media/47763/carb_icing.pdf
  #9
Old 10-28-2018, 01:48 PM
Basic Member
Default
Aircraft carb heat comes on at like 6 or 7 degrees C cant remember which is in the 40's F. Humidity is the enemy. The air going through the carb at high velocity creates wind, condenses and then freezes the moisture in the air, more moisture more ice. That's why you can still get your carb un-frozen even when its a little below freezing out when the bike is just idling. No air movement no wind chill.
M5
  #10
Old 10-28-2018, 02:22 PM
Basic Member
  #11
Old 10-28-2018, 02:40 PM
tek9tim tek9tim is online now
Currently: Not set.
Basic Member
tek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond reputetek9tim has a reputation beyond repute
Click Here to Register
  #12
Old 10-28-2018, 02:43 PM
Currently: Not set.
Basic Member
  #13
Old 10-28-2018, 02:58 PM
Basic Member
  #14
Old 10-28-2018, 03:54 PM
Basic Member
  #15
Old 10-28-2018, 04:36 PM
Basic Member
  #16
Old 10-29-2018, 07:36 AM
Currently: Not set.
Basic Member
The Following User Says Thank You to tek9tim For This Useful Post:
Misha Subo (10-29-2018)
  #17
Old 10-29-2018, 09:05 AM
Basic Member
  #18
Old 10-30-2018, 10:31 AM
Answ3r Answ3r is offline
Currently: Not set.
Basic Member
Answ3r has a reputation beyond reputeAnsw3r has a reputation beyond reputeAnsw3r has a reputation beyond reputeAnsw3r has a reputation beyond reputeAnsw3r has a reputation beyond reputeAnsw3r has a reputation beyond reputeAnsw3r has a reputation beyond reputeAnsw3r has a reputation beyond reputeAnsw3r has a reputation beyond reputeAnsw3r has a reputation beyond reputeAnsw3r has a reputation beyond repute
The Following User Says Thank You to Answ3r For This Useful Post:
Ben 500RR-S (10-30-2018)
  #19
Old 11-13-2018, 10:04 AM
Basic Member
  #20
Old 11-13-2018, 10:30 AM
Basic Member
  #21
Old 11-13-2018, 10:51 AM
Basic Member
  #22
Old 11-13-2018, 11:55 AM
Basic Member
  #23
Old 11-13-2018, 12:00 PM
Basic Member
  #24
Old 11-13-2018, 12:38 PM
Basic Member
  #25
Old 11-13-2018, 04:04 PM
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Camso fit to 2008 KTM 300 XCW. Thread Starter — Misha Subo Forum — Snow bikes Replies — 16 Last Post — 12-28-2017 10:35 PM
Thread — New Ktm 300 or thumper?? Thread Starter — upfront719 Forum — Snow bikes Replies — 32 Last Post — 11-04-2014 07:02 PM
Thread — 2008 KTM 300 XC Thread Starter — GlennRMK Forum — ATV/Motorcycle (Swapmeet) Replies — 0 Last Post — 11-01-2014 03:58 PM
Thread — KTM 300? Thread Starter — byeatts Forum — Snow bikes Replies — 4 Last Post — 06-30-2012 09:36 AM
Thread — KTM 300's Thread Starter — powderman800 Forum — Fouled Plug Replies — 5 Last Post — 06-25-2008 08:56 PM
no new posts
