Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 11-25-2017, 06:06 AM
Marcusx200 Marcusx200 is offline
Currently: Not set.
Basic Member
Marcusx200 is an unknown quantity at this point
Default Silber turbo etec clutching and afr
So i got my turbo running but havent installed the clutch kit .
I have a daughter playing with my stuff so my question is , Is kit complete now? Attach pictures. And what is the purple spring? Something i had in garage before or is it to the kit ?
Is it hard to install? Can anyone explain how?
About afr , i havent done anything with dobeck just factory setting and when i start i just see --- Readings on gauge. If i rev like 4500 i see high afr like 17.
Click image for larger version
ID:	288648   Click image for larger version
Rate this post: Yes | No
  #2
Old 11-25-2017, 07:10 AM
Mwenzel Mwenzel is offline
Currently: Not set.
Basic Member
Mwenzel is an unknown quantity at this point
Default
You will want to install the clutch kit for sure. There are pleanty of youtube videos that show how you can do this. You will need some clutch tools before doing so. Purple spring is for your wastegate. Typically they come with a 7lb installed and the lone one is a 3 or 5lb. You can give the factory dobeck a shot, but really all its good for is wall art. I bought a redline from bryce at turbo performance, also think theres a thread below about the aurora which seems pretty nice as well and seems to be getting good feedback
  #3
Old 11-25-2017, 07:15 AM
Currently: Not set.
Basic Member
Default
Also be careful with over revving. Your reeds will end up like this
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #4
Old 11-25-2017, 08:27 AM
Currently: Not set.
Basic Member
Default
Thanks for reply. How to not overrev? How long Will oem reeds last?
When i start i see 14.5 are at idle for like 2sec then --- . Is that normal ?
Just tested on the grass and mid Range i see afr 13-14 . No snow so hard to test.
No one know if the clutch kit is complete?
  #5
Old 11-25-2017, 08:43 AM
Currently: Not set.
Basic Member
Default
You will need to install the proper pin weight for the amount of boost you will run. There is a chart on the last page of the silber install manual that will give you a starting point. Your kit looks complete to me. Only difference is that i dont think mine came with ramps. I will have to go through my pile of parts to confirm. My reeds went due to either blowing belts at wot or inproper clutching for the boost i was running. Hopefully have that straightened out now tho. Your idle afr is completely normal to do that
  #6
Old 11-25-2017, 08:46 AM
Currently: Not set.
Basic Member
Default
Ok how big difference is it with turbo? Had a couple of nytro turbos but none two stroke
  #7
Old 11-25-2017, 08:50 AM
Currently: Not set.
Basic Member
Default
Quote:
That blow off valve will definitely put a smile on your face
I had a low end bog all last season which was disappointing. But you definitely will not have any issues keeping up with the 850s
The Following User Says Thank You to Mwenzel For This Useful Post:
Marcusx200 (11-25-2017)
  #8
Old 11-25-2017, 09:19 AM
Currently: Not set.
Basic Member
Default
What fuel are u running? I want 5psi boost. Planning to run 100% 102 octane race fuel
  #9
Old 11-25-2017, 10:12 AM
yamiman yamiman is online now
Currently: Not set.
yamiman has a reputation beyond reputeyamiman has a reputation beyond reputeyamiman has a reputation beyond reputeyamiman has a reputation beyond reputeyamiman has a reputation beyond reputeyamiman has a reputation beyond reputeyamiman has a reputation beyond reputeyamiman has a reputation beyond reputeyamiman has a reputation beyond reputeyamiman has a reputation beyond reputeyamiman has a reputation beyond repute
Default
what elevation?
__________________
2015 Skidoo T3 174 SHR860 with IMPULSE Turbo
2014 Summit XM 163 IMPULSE Turbo SOLD
2009 Yamaha Nytro 174" IMPULSE Turbo SOLD
  #10
Old 11-25-2017, 11:18 AM
Currently: Not set.
Basic Member
  #11
Old 11-25-2017, 11:35 AM
Currently: Not set.
Click Here to Register
  #12
Old 11-25-2017, 05:14 PM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
  #13
Old 11-25-2017, 06:43 PM
Currently: Not set.
  #14
Old 11-25-2017, 08:52 PM
chad006 chad006 is offline
Currently: Not set.
chad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond reputechad006 has a reputation beyond repute
  #15
Old 11-25-2017, 11:20 PM
Basic Member
  #16
Old 11-28-2017, 02:59 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Silber etec turbo help installation Thread Starter — Marcusx200 Forum — Ski-Doo: XM Sleds Replies — 1 Last Post — 11-19-2017 09:21 AM
Thread — Silber turbo for xm/xp etec!!!!!!SOLD!!!!! Thread Starter — wardy Forum — Turbos/Superchargers (Swapmeet) Replies — 1 Last Post — 10-15-2017 12:28 PM
Thread — Silber Turbo etec Thread Starter — blownsilver Forum — Ski-Doo: XM Sleds Replies — 1 Last Post — 03-17-2016 09:01 PM
Thread — XM 800 etec Silber turbo Thread Starter — rev xp 154" Forum — Turbos/Superchargers (Swapmeet) Replies — 2 Last Post — 02-21-2015 12:13 AM
Thread — 2013-14 Silber Turbo ETEC XM Turbo Kit Thread Starter — Silber Forum — Ski-Doo: TURBO Replies — 7 Last Post — 12-31-2013 05:53 PM
no new posts
