H
Well I have been pulling my hair out trying to get this thing fixed. Sled seems to run fine at first...when cold it will rev to 7800 and pull hard. After 10-15 minutes, seems like after it gets some heat in it, starts to fall on its face. only pulls 6500-6800 RPM.
So after getting several ideas from here, i have changed the servo motor, cleaned power valves, checked cables for free movement, adjusted cables to 34.5mm, put a new belt on, and looked over all the wiring for rubbed spots. Everything has checked out and still having issues. So what do I look at next?
Is there a possability that the cdi is bad? could the stator be getting weak? The sled seems to have no other electrical problems as far as lights and guages go; they work fine. I am stumped!!
B.T.W. It is an 06 carbed M7 with about 2500 miles.
Thanks for any help!
