B
I've got a bad belt squel on my apex. I'm guessing it is my belt deflection. Can someone tell me how to adjust belt deflection and what the proper settings should be? Thanks
The bolts and spacers/shims on the back are what you use to open or close the sheaves. You don't replace the bolts.
V-belt position Adjustment
More than 1.5 mm
(0.06 in) above the
edge
Remove a spacer
From 1.5 mm (0.06 in)
above the edge to
0.5 mm (–0.02 in)
below the edge
Not necessary
(It is correct.)
More than
(0.5 mm–0.02 in) below the
edge
Add spacer
Hopefully this helps and when its says remove a spacer it means one from under each of the bolts. Same for installing
