g2 proclimb 7 skis
Yaeger34
327
155
St cloud mn
Figured I would just make a quick topic on this as info is scattered in many topics. Want to put a set on the 18. From what I gather it requires
2 skis
2 dampeners
2 bolts/nuts
8 spacers
4 bearings
2 spindle bushings all off the 19, correct?
If so I show it being $245.
I can't find a new set or good used set of carbiders of gripper pros for that either so is this the way to go?
Mar 1, 2008
254
67
Canada
I currently does the mod
2 g2 proclimb skis
2 dampers
2 spindle axle bolts
You can reuse
- 2 spindle axle nuts
- spacers
- spindle axle (cut it)
- carbides
- handles with bolts
- sleeves on skis for spindle axle bolts
Mar 1, 2008
254
67
Canada
I will try to take a time for upload a pictures but yes, more balanced, better keel and more stronger than my g1. New gen skis are very similar to Gripper and stronger than my grippers (grippers like to eat a damper( 2 per ride, and after 1000miles my gripper are like a banana because it flex alot)
Mar 1, 2008
254
67
Canada
<a href="https://ibb.co/bM4a0U"><img src="https://thumb.ibb.co/bM4a0U/20180910_113503.jpg" alt="20180910_113503" border="0"></a> <a href="https://ibb.co/hrO2fU"><img src="https://thumb.ibb.co/hrO2fU/20180910_113435.jpg" alt="20180910_113435" border="0"></a> <a href="https://ibb.co/fMea0U"><img src="https://thumb.ibb.co/fMea0U/20180910_113354.jpg" alt="20180910_113354" border="0"></a> <a href="https://ibb.co/frUa0U"><img src="https://thumb.ibb.co/frUa0U/20180910_113345.jpg" alt="20180910_113345" border="0"></a>
Jan 20, 2011
9
78
Is the 2019 axle longer, and do you need the new dampers and axle bolts? I just order the ski bottoms, just figures all parts from 2017 would fit?
JD
