Upgrade to Premium
Reply
  #1
Old 02-09-2017, 12:01 PM
2013 M1100 Turbo 2013 M1100 Turbo is offline
Currently: Not set.
Basic Member
2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute
Default 2017 King Cat Belt Squeal on Takeoff
So I took my King Cat 9000 out for its first weekend snowmobiling and got about 70 miles on the machine. One issue that I notices is that after the machine was up to operating temp and it had been driven for a couple miles, the belt would squeal when taking off. It only does it for a split second then the sled takes off and it goes away, but when I would get stuck or start off pushing snow it would do it longer and louder (loud enough my buddies could all figure out where I was stuck) but again it would go away once moving.
I am no clutch expert but I was going to take some degreaser to both the primary and secondary clutch sheaves with a Scotch Brite pad along with taking the belt off and soaking it in soapy water to remove any potential grease on them. I was also wondering if I should give it a little longer maybe the belt needs more miles?
Cat wants me to bring the sled in and have the clutches looked at to make sure they aren't sticking, but I really don't want to drive 90 miles to drop the sled off if there could be a simple fix.
Does anyone else have any suggestions I should try?
Rate this post: Yes | No
  #2
Old 02-09-2017, 02:45 PM
89sandman's Avatar
89sandman 89sandman is offline
Currently: Meadow Muffin
89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute
Default
Did you try loosening the belt defelction?
  #3
Old 02-09-2017, 02:50 PM
Phizzer's Avatar
Phizzer Phizzer is online now
Currently: Motor Boating
Phizzer has a reputation beyond reputePhizzer has a reputation beyond reputePhizzer has a reputation beyond reputePhizzer has a reputation beyond reputePhizzer has a reputation beyond reputePhizzer has a reputation beyond reputePhizzer has a reputation beyond reputePhizzer has a reputation beyond reputePhizzer has a reputation beyond reputePhizzer has a reputation beyond reputePhizzer has a reputation beyond repute
Default
Belt squeal is usually and indicator that deflection is tight. however, on the 17 King Cat, you are unable to set belt deflection correct? I believe this setup has the Idler Bearing on the Primary clutch and "self adjusts" for deflection.
I would be leaning more towards an issue with offset, which can be adjusted with shims with the correct offset bar. If you don't have one, might be easier to just drop it off to the dealer and let them adjust it.
__________________
2015/16 Arctic Cat M8000 SnoWest Sled
2005 Arctic Cat M7 Mod Sled
"Work Hard and stay Humble"
  #4
Old 02-09-2017, 03:49 PM
Currently: Not set.
Basic Member
Default
You are correct, it has self adjusting belt deflection. I questioned them at the dealer when I was picking it up why the belt rode so high in the secondary and they indicated that its due to the self adjusting deflection. I am still going to try cleaning the clutches and belt tonight by the odd change it is the issue, but I am not holding my breath.
  #5
Old 02-09-2017, 04:43 PM
WyoBoy1000's Avatar
WyoBoy1000 WyoBoy1000 is offline
Currently: Working,
WyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond repute
Default
I run my 8 so it does that, but not so much the sled moves
__________________
18 mc (ufo) mods
16 limited, raised axys boards, xm-adjustable riser, mountain for hood, 8t drivers, ds can, slp exhaust. (Coming tki drop belt Drive) then clutch until happy.
Assume = when you as$,u,me you make an as$ out of u and me. Think, ask, get the facts and then go forward.
  #6
Old 02-09-2017, 05:48 PM
Currently: Not set.
Basic Member
Default
Well I went to clean up my clutches and found a black ring on the primary clutch. I am cleaning it off with brake cleaner and Scotch Brite. Fingers crossed that was the problem.
  #7
Old 02-10-2017, 01:43 AM
WyoBoy1000's Avatar
Currently: Working,
Default
Squealing is simply from tight deflection. That's it.
__________________
18 mc (ufo) mods
  #8
Old 02-10-2017, 02:02 AM
sno*jet sno*jet is offline
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
my 8000 has a ring of residue around the primary i notice after driving slow. i cleaned it off in between rides a few times before realizing it just appears while unloading/backing into my shop. If i jack up the back and rip it good a few times the ring is gone. so i quit wasting time/cleaner on it.
i would check your secondary offset with an alignment tool, if you can get one for that model.
However 90 miles to let the dealer look at it aint too bad imo. If he finds something anyways.
  #9
Old 02-10-2017, 09:11 AM
Currently: Not set.
Basic Member
Default
That's the thing. When I start the sled and as soon as it gets to operating temp I take off or load onto a trailer there is no squeal (this was even driving it across a dirt floor in our quonset where there should be all kinds of resistance). Its only after I get it good and hot from riding down a trail or in powder that it starts to squeal when taking off.
Sorry if I am being repetitive in my explanation but I don't see why it wouldn't do it after just starting it and driving vs when its hot. But again, I am by no means an expert on clutches.
  #10
Old 02-10-2017, 11:03 AM
89sandman's Avatar
Default
Belt gets a lot more sticky when it's warmed up, takes at least a mile or 2 to get it fully up to temp, this is probably why it only happens after the belt is up to full temp.
  #11
Old 02-11-2017, 08:25 PM
nm2708 nm2708 is offline
Currently: Not set.
nm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond reputenm2708 has a reputation beyond repute
Click Here to Register
  #12
Old 02-12-2017, 03:07 PM
Currently: Not set.
Basic Member
  #13
Old 02-15-2017, 10:03 AM
Currently: Not set.
Basic Member
  #14
Old 02-15-2017, 10:28 AM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
  #15
Old 02-15-2017, 11:22 AM
Currently: Not set.
Basic Member
The Following 2 Users Say Thank You to 2013 M1100 Turbo For This Useful Post:
nm2708 (02-16-2017), Scott (02-15-2017)
  #16
Old 02-27-2017, 02:51 PM
Currently: Not set.
Basic Member
  #17
Old 03-01-2017, 08:27 AM
wood51282 wood51282 is offline
Currently: Not set.
Basic Member
wood51282 is an unknown quantity at this point
  #18
Old 03-01-2017, 12:46 PM
Currently: Not set.
Basic Member
  #19
Old 09-11-2018, 08:05 AM
Currently: Not set.
Basic Member
  #20
Old 09-17-2018, 07:18 AM
zl5600 zl5600 is offline
Currently: Not set.
Basic Member
zl5600 has a brilliant futurezl5600 has a brilliant futurezl5600 has a brilliant futurezl5600 has a brilliant futurezl5600 has a brilliant futurezl5600 has a brilliant futurezl5600 has a brilliant futurezl5600 has a brilliant futurezl5600 has a brilliant futurezl5600 has a brilliant futurezl5600 has a brilliant future
  #21
Old 09-17-2018, 07:21 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2017 Arctic Cat King Cat 9000! Thread Starter — RACINSTATION Forum — Arctic Cat: 1100 ProClimb Replies — 2 Last Post — 09-10-2016 02:46 PM
Thread — Belt squeal Thread Starter — Glckdvd1 Forum — Polaris: GEN 2 Replies — 3 Last Post — 12-15-2013 02:52 PM
Thread — Belt squeal Thread Starter — Strickland3 Forum — Polaris: IQ Replies — 3 Last Post — 02-13-2012 10:37 PM
Thread — New Belt Squeal Thread Starter — HouseCO Forum — Polaris: Pro-Ride Replies — 8 Last Post — 02-08-2012 04:54 PM
Thread — Belt squeal Thread Starter — Wire4Money Forum — Arctic Cat: M Series Replies — 9 Last Post — 01-24-2011 04:59 PM
