to change gears or not to change gears, that is the question
E
Jan 25, 2009
355
13
Erie Colorado
I have a project going on and would like to figure out if I need to change my gears. The sled is a 02 rmk 800 with a 16g turbo. I would like to also do the work to fit a 174 on it. So will the stock gears that have pushed my 159 be enough? I am thinking yes but would like a second opinion!
sled_guy
3,566
843
Riverton, Utah
Is that 159x2 to 174x2.5? That's a pretty big jump. The turbo power should drive it fine, but out of the hole, when you aren't on the boost is where you'll see issues I would think. I ran a 166 for a while and the belt heat generated right off of idle was pretty bad even though I had plenty of HP to move the track once I got going.
You might could dial back the initial angle of the helix to compensate for it and keep the same gearing... that would be a good option so you don't give up topend track speed from the turbo.
sled_guy
Sep 14, 2006
2,014
95
48
50
On the toilet
id change the gears, how fast do you really need to go? id rather have acceleration than top end
I doubt he is worried about how fast, more like how much track speed.
I'd leave it alone if its still stock gearing. Like Sledguy said, maybe dial back the initial angle to get it moving a bit easier.
You are going to have about 70mph track speed.
ullose272
3,371
960
boise idaho
you think he will still have 74 mph track speed with a 174 track? i would go to a 40 or 41 bottom. i guess it kinda depends on what you do? are you into hill climbing or boondocking or what? hill climb maybe stick with stock gearing, but playin in the trees? id gear it, but i guess with a 174 track your probly gonna climb hills
Tec
679
308
Fraser, CO
Mitsu turbo's are oil and water cooled, what did you do for water lines? Are you running a big/small or evo3 16g?
SixtySevenGT
803
116
Middleton, Idaho
What are the Stock Gears / Never Hear ?
20 42 does a good job of taking out the slack in the chain
[/IMG]
