Ascender Plastics on 17 or older
jakey-boy
1,447
787
Idaho Falls
instagram.com
Has anyone done it yet? Compiled a parts list of what all is needed?
Mine is turbo application so won't need intake but before I start ordering parts I am wondering if anyone has done it yet.
Lots of little pieces on the parts fiche curious if they are all necessary.
Speed Shop Inc.
421
205
Cannon Falls, MN
www.speedshopinc.com
We have kits available in to upgrade your machine in two versions. We have the narrowest 2018 plastic, and it comes with our Promax cold air intake. And we also have the RS style black plastic that will bolt right on the 2012-2017 models.
Keep in mind the 2012-17 models have a wider oil tank than the 2018 models. So to upgrade to the 2018 plastic most people will upgrade to our lightweight chaincase cover and oil tank kit.
Also keep mind that you should install our Ascender series running boards because the new tunnel is narrower. Even with our original design running boards, which are 1" narrower than stock, the front loop is different because the footwell area is different for 2018.
If you have a 2017 mountaincat, the 2018 plastic kit will fit, but because it has the newer style footwell area.
The complete kit with our cold air intake is $1295.
We have developed a new pod with recessed LED headlights, air intake, fly screen, gauge mounting, and clear headlight cover that will come with the kit. I will have pictures of the production pieces later this month.
Here is a link to the kit on our website.
http://www.bd-xtreme.com/index.php?id_product=645&controller=product
2018 prolite hood green b.jpg 20069-OIL.jpg 2018 hood 8-B.jpg promaxintake-f.jpg promaxintake-g.jpg
jakey-boy
1,447
787
Idaho Falls
instagram.com
Here's what I have put together so far. It doesnt necessarily have all of the small hardware pieces as a lot of that should be reusable off the older sleds. Please add or adjust if you have suggestions. These are retail cat prices.
TAG PART # Description Price QTY Total
Side Panels $575.61
1 5718-600 Panel, Side w/o Decals - Right - Black $147.95 1 $147.95
3 1623-939 Nut, U $0.69 8 $5.52
12 5718-601 Panel, Side w/o Decals - Left - Black $147.95 1 $147.95
17 5718-790 Plate, Skid w/Foam - Right - Black $81.95 1 $81.95
27 5718-791 Plate, Skid w/Foam - Left - Black $81.95 1 $81.95
45 7606-621 Brace $56.95 1 $56.95
46 2623-164 Screw, Self-Tapping $0.89 2 $1.78
Hood Parts $457.18
1 7606-138 Hood w/o Decals - Right - Black $77.95 1 $77.95
1 7606-139 Hood w/o Decals - Left - Black $77.95 1 $77.95
9 5718-328 Plenum, Intake - Upper $128.95 1 $128.95
12 7606-258 Vent - Right $13.95 1 $13.95
12 7606-259 Vent - Left $13.95 1 $13.95
16 7606-056 Bezel, Vent - Right $15.95 1 $15.95
16 7606-057 Bezel, Vent - Left $15.95 1 $15.95
19 2623-004 Nut, Push $2.99 2 $5.98
20 2623-003 Pin, Retaining $12.95 2 $25.90
4 7606-050 Plenum, Air Intake - Lower Front $28.95 1 $28.95
Console $74.39
1 7606-469 Console - Black $51.95 1 $51.95
4 7606-265 Knob, Holddown $0.89 2 $1.78
5 7606-296 Plate, Backing $0.89 2 $1.78
6 2623-155 Clip, Retaining $8.95 2 $17.90
7 2623-171 Washer, Flat $0.49 2 0.98
Front frame
29 7606-053 Belly Pan - Front 1 $15.95
Clutch cover
3 3707-078 Guard, Belt | (inc. 4-5) 1 $103.95
jakey-boy
1,447
787
Idaho Falls
instagram.com
Got my plastics conversion completed over the weekend. Turned out awesome. The install was very easy. Well worth it this sled is skinny skinny now! I did end up with several pieces I didn't need and also missing a few but overall wasn't too bad. With the new BDX kits being cheaper and offering more options I would probably consider those if I was doing it again just to not have so much back and forth of returning and purchasing parts. But if you get a good deal on cat parts from your dealer you may still end up cheaper piecing it together.
DDECKER
4,770
1,780
CRAIG COLORADO
lets see it good sir!!
Dec 21, 2010
17
I'm thinking of doing the Mountain Fit hood for the ascender and then the rest OEM.. What are your thoughts on that? I'm thinking it would make the whole thing go a little smoother, with a better/lighter finished product.. do you have a updated parts list for what you did? I have a 17 as well. and currently doing tki belt drive.
jakey-boy
1,447
787
Idaho Falls
instagram.com
I updated the list above to be more accurate but still might end up with extra hardware and missing small pieces. I had a bad experience with my mountain fit hood ingesting snow so I prefer the factory stuff it is really pretty light its just better built. Keep in mind my list doesn't include any intake parts at all as I have a turbo intake and reused everything off my 16 for that. Especially if you need intake parts tho that BDX kit for $1000 is a good deal. I was easily close to that without any intake.
