I have a Vipec ECU tuned by Cody Phillips racing for a 2863 turbo on 8 lbs on 50/50 pump/100ll and 12 lbs on 100ll for a Polaris PRO. The unit has a switch for the low & high boost settings and a switch for 10% fuel add in case you encounter questionable fuel. Set up with Auxillary injectors, comes with the aux injectors, injector boot, wire harness & switches with console and AFPR ready to install $1400.
