O
I set out to check the tps setting on my '12 pro r 800.
Once connected, I found the initial idle setting at .963 V.
I pulled the trigger to check the sweep, all looked good. No drops or flat spots.
When I pulled to WOT, the meter went to O.L. (open lead) It climbed to about 4.000V then to O.L.
so, I unhooked throttle cable and backed off idle screw.
My base setting was .713V
I adjusted to .698-.700V with screws tight.
Then adjusted idle screw to .940 with jam nut tight.
Reconnected throttle cable and did another sweep, making sure it went back to .940V
Still at WOT, it goes to O.L.
I then switched to the next range on my meter. It shows 4.11V
But in the 4.000 scale, it goes to O.L.
Tried with 2 different meters, same O.L.
sled runs good, plugs are always a little fat, that's why I checked the tps.
So, question is, why the O.L. in the .000 scale, and were my initial base numbers off enough to make a difference in how sled runs. (haven't rode yet )??
