Not sure if im missing something but is ski pressure more to do with front of track more or less contact with snowJust wanted to give everyone a heads up. Yes the shocks will fit for a 15 38'' to a 16 36'' but you will have a ton a ski pressure and sled wants to dive bad in the powder. Its actually hard to ride and will be pulling them asap
So am I getting this right. To go from a 38" kit you need
A-Arm kit
Rebuild shocks to install Spacer.
And the internal valve's should also be changed to match the suspension.
And with all this is there enough gain in ride?
I just installed my 2016 front end kit too. Yes, the shock length has to be adapted for the narrower front end. As I understand it, the shocks can either be internally shortened by an internal bumper or the preferred method of cut and threaded (which gives you more shock travel). However, if you have them cut and threaded, there is no going back to the original length.
QUOTE]
I guess I'm a bit lost by where this headed. I was planning to go to the '16 front end on my '15. The dealer has a guy who can internally shorten the shock rather than cut and shorten and do it locally. If I go that route, are there still issues with tie rod clearance, ski pressure etc? I've heard great things about the '16 front end but don't want to spend the money if there are significant drawbacks.
