Y
Need some help my 2005 900 had a bad bog under 5000rpm so I checked tps and tss did not seem to help and checked fuel psi its 60 psi added Seafoam to tank and bog does not seem as bad now but will backfire now and then when coming off throtle down to idle. idle is not consistent some times right at 1700 others around 2200 and at times down to 1200-1300 but will keep running and then once in awhile if I turn it off its very hard starting 6-10 pulls when others time would be one pull on warm engine. also there is more then normal exhaust markings on the side panal above the outlet would a exhaust or air temp sensor fail to default with out a code? used it this past weekend for 4 days first 3 ran 100% for 650 miles and then last day from the first pull has problems but did stay running to get me home the last 150 miles.
Any ideas?
Thanks
Any ideas?
Thanks
