engages about 4600 and it bogs between that and about 5000
Note: this_feature_currently_may_not_be_available_in_some_browsers
I'm still thinking it's an injector or broken wire to the injector, this is where mine had a broken wire right at the connector ....
that doesn't look like the injector wires, it looks like the harness that goes to your det,water temp sensors??
2 wires that come directly off the injector. From the factory the are direct wired into the loom, when the dealer replaced the injectors they spliced the new wires into the old harness.
snowman 429 what wire are you pulling your 12 volts off of for the box gauge ect?
Are you talking about the EBC? If so I'm not running one.Ill try and look at mine this weekend,The box was tied into the red blue by the ecm if my memory serves me correct and it was freaking out the ecm. I moved it to one of the wires off the regulator and it solved the problem but i don't remember the color of that wire.
