New from KMOD, 37" wide complete front suspension.
This new front suspension draws on the success that KMOD had with their complete front suspension for the ProRide-Mtn chassis and has custom tailored it for the new AXYS chassis. KMOD's 37" front for the ProRide-Mtn sleds received very positive feed back from customers; those same customers will be looking for the same on the Axys.
Features:
- Specific construction for the AXYS-Mtn. sleds
- Cad/Cam designed and mfg.
- 4130 Cromoly, large OD, lightweight, tig welded construction
- Factory ride height is preserved using STOCK 16.63" shock length
- Swaybar compatible
- Uses factory pivot, shims and snap rings (new bushings are provided with the KMOD arms)
- Includes Upper and lower A-Arms, all Ball-joints, tie-rods, pivot bushings hardware and instructions.
- Same weight as stock.
- Price $695 USD complete.
Talking with Kevin about this in depth....He said that with the KMOD front suspension for the AXYS-Mtn., all aspects of geometry have been analyzed and taken into account in terms of caster, camber, ackerman-angles, toe and bump-steer-avoidance. All of this is designed to translate into improved nimbleness without being "tippy" ...and tenacious bite into the sidehill without "paneling out".
This new front end is designed to be stronger than the factory arms with the ability to deform without breaking... and still protect the bulkhead and chassis.
Click Here for more details on the KMOD webpage.
Factory Pivot-Bushing design is retained.
