Full of gas I put a 6 volt charge to it and it just hums, I either have a bad stator if 6 volts is not enough. Just wondering if anyone else has had to replace AC fuel pump.
Yeah i have had to replace mine twice. Although both times were my fault i forgot to put fuel stabilizer in the gas over the summer. When that gas get old without stabilizer it turn into like syrup and plugs up the pump. I don't know if you are having this problem or not. Did you take the line off down by the injectors to see if you are getting fuel there. Sometimes the injectors will stick after sitting for awhile. If you are getting gas to the fuel rail but not past the injectors tap the injector with a screwdriver handle or something. Can also clean them with some carb cleaner. I have had that happen before also. Hope it works out for you. If you need a fuel pump give rvsports a call ask for troy, they normally have some good used ones at least when i needed one. He is Highmarck18 on here. Good luck.
