Holz but it makes no difference on setup,
What ever you want to think.ound:
Its not what I think, if you want to come over I'll prove it. I have changed my suspension many times to find where it performs and letting it sag is only lowering your suspension travel which in turn will make you drag faster. to much pre load on the front and you just as well have a short track. As for the valving it has a different ride and better performance but the suspension still works the same.
To anyone with the Holz revalve on the Float setup,what preload are you running on the dual spring frt shock on the skid? THKS
My buddy has the Holz set-up, and he has to run more air in rear shock for the same performance.
If your spending the money on the Burandt kit and setting it up "AS per the Book" your loosing a lot of the potential of the suspension.
Some may need more pressure, some less. But your telling people to set it up a certain way and not try others settings.
I have tried my set-up from 100 to 150. 125 is my sweet spot.
I only know this because I have tried other settings.
