Upgrade to Premium
Arctic Cat: M Series 2005-2011, all models in the M-series chassis
Reply
  #1
Old 02-27-2019, 08:19 PM
Tmhcycle Tmhcycle is offline
Currently: Not set.
Basic Member
Tmhcycle is an unknown quantity at this point
Default 1994 panther 440 wont start with drive belt on
Ok so here is what its doing, it wants to start but wont i took off drive belt and it started right up and ran perfect. I did put a new belt on it and its in correct direction even tried it the other way but wont start with it on. Ive cleaned carb rebuilt fuel pump new gas lines cleaned gas tank, has new gas. Spark is good. So since it starts on one pull and idles and revs perfect with belt off im thinking it’s something to do with new belt or clutch. Im going to try with old belt and see what happens. But any help would be great. Ps it worked fine before, but sat and needed to clean carbs and figured a new belt would be needed(dryrot) .
Rate this post: Yes | No
  #2
Old 02-28-2019, 04:15 PM
zilla zilla is offline
Currently: Not set.
Basic Member
zilla has a reputation beyond reputezilla has a reputation beyond reputezilla has a reputation beyond reputezilla has a reputation beyond reputezilla has a reputation beyond reputezilla has a reputation beyond reputezilla has a reputation beyond reputezilla has a reputation beyond reputezilla has a reputation beyond reputezilla has a reputation beyond reputezilla has a reputation beyond repute
Default
It sounds like your explaining a to tight belt and its bogging down the little single carb ? motor. With that belt your describing, it should right now look like its riding high in the secondary clutch. 2 things you could do. One keep the proper belt sheave thickness as recommended but go a little longer on the belt, but you bought one I guess already. 2 is to open up secondary and install a shim to widen the distance in between secondary sheaves to drop belt down in sheave, giving you more distance between clutches. Old school. When you learn this you'll be able to keep your belts operating more efficiently. keep up the good work
  #3
Old 02-28-2019, 10:44 PM
turboless terry's Avatar
turboless terry turboless terry is offline
Currently: Not set.
turboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond repute
Default
Guessing you need to put some washers or shims back in your secondary to get your belt deflection right.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — dtc fuel pump drive circuit? sled wont start Thread Starter — k_newman66 Forum — Polaris: Pro-Ride Replies — 2 Last Post — 03-13-2016 09:14 PM
Thread — T-3 with TKI belt drive and E-Start Thread Starter — snowpatrol Forum — Ski-Doo: XM Sleds Replies — 2 Last Post — 06-21-2015 02:30 PM
Thread — polaris defrost bag , e start , and complete belt drive Thread Starter — penny1l Forum — Misc. Sled Parts Replies — 1 Last Post — 06-16-2014 10:12 AM
Thread — AC Panther 440 track change? Thread Starter — Tiz Forum — Arctic Cat: Powder Special and older Replies — 7 Last Post — 01-13-2013 03:40 PM
Thread — 1994 Arctic cat panther 550 w/ 2upvs 1999 RMK 600 Thread Starter — deaner Forum — General Snowmobiling Replies — 13 Last Post — 11-01-2008 11:06 PM
no new posts
