Upgrade to Premium
Arctic Cat: M Series 2005-2011, all models in the M-series chassis
Reply
  #1
Old 02-16-2019, 10:54 AM
thunderalley thunderalley is offline
Currently: Not set.
Basic Member
thunderalley is an unknown quantity at this point
Default 2007 m1000 boondocker numbers
I have a 2007 m1000 with 162" track, SLP pipe and can and reeds with exhaust porting...I also have a boondocker box and I need some numbers ????
Rate this post: Yes | No
The Following User Says Thank You to thunderalley For This Useful Post:
thunderalley (02-16-2019)
  #2
Old 02-19-2019, 12:01 PM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
I had this same sled with similar mods...but not the boondocker controller. And regardless, anyone's numbers will have you needing to do what I'm suggesting below anyway.
At idle and low end, leave everything alone at zero...this tends to work best. Just make sure you don't have a lean bog going on. But, I never had to add to the low end on my sled.
Mid range, add a bunch at first and make sure it falls on it's face. Then pull in from there to clean up. It will take a bit to find that right number that works for the over the hood, plugged exhaust hot pipe/temps yet isn't too lean for the opposite conditions. SLP high flow intake helped with this issue.
On top, start out rich until it falls on its face and pull in from there. Keep as much fuel on the top as you can tolerate...the more fuel, the better this motor runs.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — m1000 boondocker numbers Thread Starter — alaska_racer9974 Forum — Arctic Cat: M Series Replies — 4 Last Post — 01-22-2015 01:04 PM
Thread — 2008 m1000 boondocker fuel controller numbers Thread Starter — leeindubois Forum — Arctic Cat: M Series Replies — 0 Last Post — 11-22-2012 07:40 PM
Thread — 08 M1000 Boondocker numbers? Thread Starter — meakin46 Forum — Arctic Cat: M Series Replies — 2 Last Post — 11-30-2011 09:38 PM
Thread — 2007 d7 boondocker turbo numbers Thread Starter — rmk700rules Forum — Polaris: TURBO Replies — 3 Last Post — 01-07-2011 12:50 AM
Thread — input on boondocker numbers for m1000 w/09 reflash & slp pipe Thread Starter — never enough snow Forum — Arctic Cat: M Series Replies — 0 Last Post — 05-03-2009 09:10 AM
no new posts
