Upgrade to Premium
Arctic Cat: M Series 2005-2011, all models in the M-series chassis
Reply
  #1
Old 02-05-2019, 10:25 PM
durangorider durangorider is offline
Currently: Not set.
Basic Member
durangorider is an unknown quantity at this point
Default Engine failure
Could I get some insight on what caused this. It's on a 09 m8 with only 980miles. Had a slight pop noise then died. And couldn't get it to stay running after that.
https://photos.app.goo.gl/w7aockG2kt31QHNU9
https://photos.app.goo.gl/Z7FTBgADXkDyZrMD7
Rate this post: Yes | No
  #2
Old 02-06-2019, 11:06 AM
Readymedic's Avatar
Readymedic Readymedic is offline
Currently: 2019 is awesome!!
Readymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond repute
Default
Way too hot. A lean condition IMO.
  #3
Old 02-06-2019, 07:29 PM
Bradley T Bradley T is offline
Currently: Not set.
Basic Member
Bradley T is an unknown quantity at this point
Default
The piston wash doesn’t look like it was lean... I would check to insure something didn’t get ingested into your in-take. To me, it looks like something was banging around and thus you have indentions in both your head and piston. If it was a lean burn, you would have scaring on your clyinders.
  #4
Old 02-06-2019, 07:42 PM
kidwoo's Avatar
kidwoo kidwoo is offline
Currently: keeping tahoe sledding
kidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond repute
Default
Any ring bits get in there?
Almost looks like some rod bearing indentations too.
Pull the jug and see what's up with the rods. If that didn't have something metal break loose, that's some seriously nasty det.
__________________
www.sierrasnowmobilefoundation.com
Your loud can sounds stupid
2018 AXYS
2016 M8000
  #5
Old 02-06-2019, 09:04 PM
89sandman's Avatar
89sandman 89sandman is offline
Currently: Meadow Muffin
89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute
Default
I would guess a broken piston skirt. Let us know who wins
  #6
Old 02-07-2019, 02:24 PM
Readymedic's Avatar
Default
I have had flakes of aluminum on the head and pitting, on carbed sleds..
  #7
Old 02-10-2019, 07:48 AM
snoluver snoluver is offline
Currently: Not set.
snoluver has a reputation beyond reputesnoluver has a reputation beyond reputesnoluver has a reputation beyond reputesnoluver has a reputation beyond reputesnoluver has a reputation beyond reputesnoluver has a reputation beyond reputesnoluver has a reputation beyond reputesnoluver has a reputation beyond reputesnoluver has a reputation beyond reputesnoluver has a reputation beyond reputesnoluver has a reputation beyond repute
Default
Definitely a foreign object got into the cylinder. Probably a broken ring. I wouldn't think a skirt broke with only 980 miles. But a ring could have been stuck from the sled sitting a long time. That would kinda make sense with that few miles on it.
  #8
Old 02-10-2019, 10:09 AM
CATSLEDMAN1 CATSLEDMAN1 is online now
Currently: one ski and a KTM
CATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond repute
Default by the looks
most of the time when I've fixed arctic cat motors with this look its the result of DETONATION and its been going on for some time, maybe 50-100 miles, maybe since new.
the most likely cause is lean fuel air mixture causing the toooo lean fuel mixture along the outer edge of the piston to explode with a bang instead of the ideal soft push ( technical term as pointed out detonation/deto ), most likely an air leak. Seals on these engines don't go bad sitting for that length of time. Air leak from base gasket very likely, loose stud bolts/nuts. Leaks around the reed valves/reed cages, blown a few belts, crank seals with belt threads stuck in them.
Just a little detonation now and then for 900 miles will anneal the piston crown which allows the ring lands to widen and the rings to flutter and not transfer heat off the piston crown, then under a load in the rpm range where the deto is the worst , a ring end may weld itself to the piston wall for a mili second, break off and go around through the transfer ports and dingle up the outside edge of the piston.
However I would expect when you pull the piston, you will find rings intact, skirt intact. When the center of the head shows little or no scaring, the outside edge of the piston is eroded from little bits of aluminum becoming liquid for a moment and bounding around . The pop you heard was the last straw, not the start of this problem.
Timing could cause this, but the timing on these motors is same for both pistons, one good piston one bad piston, rule out timing.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to CATSLEDMAN1 For This Useful Post:
kidwoo (02-10-2019)
  #9
Old 02-10-2019, 11:28 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
if it sat for a long time I hope you drained the old gas out of it!
If not you can get det and this can break off the ground strap on the plug and this will leave the little J marks on the piston top.
did all the plugs have the ground strap?
did you drain the old gas?
where any of the plugs loose?
  #10
Old 02-10-2019, 05:08 PM
Readymedic's Avatar
  #11
Old 02-11-2019, 10:30 AM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 02-11-2019, 06:22 PM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
  #13
Old 02-13-2019, 06:21 PM
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2013 m8 engine failure Thread Starter — durangorider Forum — Arctic Cat: M Series Replies — 9 Last Post — 03-06-2017 01:54 PM
Thread — Looking for Feedback ( engine failure) Thread Starter — Piped Bravo Forum — Arctic Cat: Proclimb M Replies — 11 Last Post — 01-27-2016 05:29 PM
Thread — What to do about an atv engine failure? Thread Starter — zr600 Forum — Fouled Plug Replies — 6 Last Post — 03-10-2013 10:26 AM
Thread — 09 M8 engine failure Thread Starter — Eric B Forum — Arctic Cat: M Series Replies — 4 Last Post — 01-03-2011 08:32 AM
Thread — 07 800r engine failure Thread Starter — skidoojames151 Forum — Ski-Doo Replies — 0 Last Post — 12-26-2007 10:42 PM
no new posts
