Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 02-28-2011, 01:44 PM
JTAB JTAB is offline
Currently: Let it Snow
JTAB has a reputation beyond reputeJTAB has a reputation beyond reputeJTAB has a reputation beyond reputeJTAB has a reputation beyond reputeJTAB has a reputation beyond reputeJTAB has a reputation beyond reputeJTAB has a reputation beyond reputeJTAB has a reputation beyond reputeJTAB has a reputation beyond reputeJTAB has a reputation beyond reputeJTAB has a reputation beyond repute
Default Boosted Apex Issues
Just want to pick a few brains on this one. 2006 Apex motor Impulse Race Kit 2871 Tial turbo. I am getting codes 13, 15, and 20 sled runs but can't seem to keep it running in the 12's on the Air Fuel guage. Idles in the 13's and as I accelerate and it starts to make boost at say 2-8lbs and 7000 to 8500 RPM it will go rich and run at 10 on the A/F Guage. Which makes it hard to ride cruising across a meadow, blubbers and runs rich. I have tried different controllers and the same results if I take away boost fuel in the middle I can't add enough main jet to make up for it. I have had my controller remapped and that has helped but not curing the problem. Using a Purelogic controller and I have a stock Attitude controller as well to compare with. I know some of you guys don't like these controllers but I have had 4 good years running this one.
Because of the codes I think I have other issues, have done all the tests , swapped computers and all the sensors and no luck. In Diagnostic's D2 it shows 95 and on D3 it shows 9 that seems like a huge spread for atmospheric pressure change on a not running engine. The manual doesn't help me out and tell how much difference there should be. I have pressure tested the system and I can't find any leaks, tested fuel pressure changed plugs etc.
If the Map sensors are not working properly that would make sense of what is happening the sled is fighting it self. It's telling it to add fuel and it does not need it. ANY HELP GREATLY APPRECIATED
Jason
Rate this post: Yes | No
  #2
Old 02-28-2011, 02:03 PM
EZmoney EZmoney is offline
Currently: Not set.
EZmoney has a reputation beyond reputeEZmoney has a reputation beyond reputeEZmoney has a reputation beyond reputeEZmoney has a reputation beyond reputeEZmoney has a reputation beyond reputeEZmoney has a reputation beyond reputeEZmoney has a reputation beyond reputeEZmoney has a reputation beyond reputeEZmoney has a reputation beyond reputeEZmoney has a reputation beyond reputeEZmoney has a reputation beyond repute
Post
Have ya tried a new set of plugs? These sleds will run but like crap if the plugs are fouled. Sounds like you checked some of the obvious
  #3
Old 02-28-2011, 02:06 PM
Default
Sorry forgot to tell tried new plugs.
  #4
Old 02-28-2011, 05:12 PM
Currently: Not set.
Post
Have you had this sled out since the build and it was running good? Or having issue's since the first ride?
  #5
Old 02-28-2011, 05:43 PM
mtsnowgo mtsnowgo is offline
Currently: Waiting for weekends..
Basic Member
mtsnowgo has a reputation beyond reputemtsnowgo has a reputation beyond reputemtsnowgo has a reputation beyond reputemtsnowgo has a reputation beyond reputemtsnowgo has a reputation beyond reputemtsnowgo has a reputation beyond reputemtsnowgo has a reputation beyond reputemtsnowgo has a reputation beyond reputemtsnowgo has a reputation beyond reputemtsnowgo has a reputation beyond reputemtsnowgo has a reputation beyond repute
Default
Looks like all the codes that are being throw have to do with the air intake sensor and pressure. Error 20 reads "Atmospheric pressure defective values are detected due to the internal malfunction fixes the intake air pressure and atmospheric pressure to 85.0 kPa. Able Able."
  #6
Old 02-28-2011, 06:54 PM
BigFish BC BigFish BC is offline
Currently: Time to start breaking $hit theres snow on the ground.
BigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond repute
Default
my buddies did similar this year it was the air pressure sensor from the air box just replaced it & all good.
  #7
Old 02-28-2011, 07:11 PM
Default
Quote:
Worked good first trip and been acting up ever since.
  #8
Old 02-28-2011, 07:13 PM
Default
Quote:
It's new and the TPS is new and a new Map sensor as well.
  #9
Old 02-28-2011, 07:20 PM
obile obile is offline
Currently: doin the snow dance
obile has a reputation beyond reputeobile has a reputation beyond reputeobile has a reputation beyond reputeobile has a reputation beyond reputeobile has a reputation beyond reputeobile has a reputation beyond reputeobile has a reputation beyond reputeobile has a reputation beyond reputeobile has a reputation beyond reputeobile has a reputation beyond reputeobile has a reputation beyond repute
Default
check for condensation in the vac lines going to the atmosphere sensor pull the lines and blow them all out. had this happen once on mine. does it rest in a heated shop to dry things out or stuck out in the cold?
  #10
Old 02-28-2011, 07:41 PM
  #11
Old 02-28-2011, 08:58 PM
Turbo11T Turbo11T is offline
Currently: EVOLVING
Turbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond repute
Click Here to Register
  #12
Old 02-28-2011, 09:46 PM
Currently: Not set.
  #13
Old 03-01-2011, 07:41 AM
  #14
Old 03-01-2011, 11:16 AM
Currently: Not set.
  #15
Old 03-01-2011, 01:59 PM
NM NM is offline
Currently: If you settle for mediocrity...that is what you will come to expect
NM has a reputation beyond reputeNM has a reputation beyond reputeNM has a reputation beyond reputeNM has a reputation beyond reputeNM has a reputation beyond reputeNM has a reputation beyond reputeNM has a reputation beyond reputeNM has a reputation beyond reputeNM has a reputation beyond reputeNM has a reputation beyond reputeNM has a reputation beyond repute
  #16
Old 03-01-2011, 02:02 PM
  #17
Old 03-01-2011, 05:47 PM
TurboMatt TurboMatt is offline
Currently: thinking
TurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond reputeTurboMatt has a reputation beyond repute
  #18
Old 03-01-2011, 11:26 PM
  #19
Old 03-02-2011, 10:17 AM
  #20
Old 03-04-2011, 12:57 PM
  #21
Old 03-04-2011, 01:54 PM
Currently: thinking
  #22
Old 03-04-2011, 08:46 PM
  #23
Old 03-05-2011, 04:22 PM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Boosted 06 Apex Thread Starter — mountain man Forum — Yamaha (Swapmeet) Replies — 3 Last Post — 01-11-2010 11:17 AM
Thread — boosted apex pics Thread Starter — yamaha4life Forum — Yamaha Replies — 4 Last Post — 09-02-2009 05:09 PM
Thread — boosted apex vs boosted nytro, need help! Thread Starter — mattymac Forum — Yamaha Replies — 18 Last Post — 05-26-2009 12:02 AM
Thread — fabcraft in a boosted apex? Thread Starter — boostjunky Forum — Suspension/Shocks (Swapmeet) Replies — 1 Last Post — 08-23-2008 10:42 PM
Thread — Boosted fuel issues Thread Starter — KC Boost Forum — Yamaha Replies — 9 Last Post — 04-23-2008 07:56 AM
no new posts
